Multi-channel EV battery module tester
"Workers was both easy to learn and powerful enough to build a multi-module EV battery tester with clean APIs. I have zero regrets choosing it."
APPLICATION BUILT
I developed an application for an EV battery module tester capable of testing up to six battery modules independently. One of the major advantages of the Workers architecture was the ability to create a reusable test-channel UI Worker once and then scale it across all six channels with minimal additional effort.
The application was successfully deployed to multiple customer locations and delivered as part of a production testing system.
GETTING STARTED
The framework was easy to learn thanks to the short explanation videos, sample projects, and documentation. The familiar QMH-style architecture also made the transition approachable.
The Workers Debug Server quickly became one of the most valuable tools during development and debugging.
IMPACT ON DEVELOPMENT
The modular Worker-based architecture allowed each hardware subsystem to be developed and debugged independently. Once a Worker’s public API was functioning correctly in isolation, integrating it into the larger application became significantly more reliable and predictable.
The framework’s scripting tools also accelerated development while reducing coding mistakes and repetitive boilerplate work.
The final application received very positive feedback for its fast loading times, responsive UI, and quick shutdown behavior.
RECOMMENDATION
I would definitely recommend Workers to other LabVIEW developers. The framework is approachable for newer developers while still being powerful enough for advanced architectures and scalable applications.
The active community support was also extremely helpful whenever questions came up during development.
2
