I’m working on an operation flow of "parse command – execute action – return result". Both the command parsing and result returning inherit from a base class, while the action execution is overridden by specific Workers. During the action execution, I need to replace part of the result data into the return data cluster. However, when using this setup, I noticed that the methods inherited from the base class only access the private data of the base class. How can I implement a mechanism for the base class and subclasses to share data content? Since I feel that global variables or FGVs (Functional Global Variables) would disrupt the clean calling relationship of the Workers, I’d like to ask if you have any other good solutions.
Design Pattern for Base-Class/Subclass Data Sharing in Command-Execution-Result Workflow
1
